Propane tankless water heater issues (gas line sizing, regulator, temp
Communauté Plomberie Productions d’eau chaude, chauffe-eau électrique ou au gaz Propane tankless water heater issues (gas line sizing, regulator, temp
  • Ce sujet contient 2 réponses, 3 participants et a été mis à jour pour la dernière fois par Anonyme, le il y a 5 années et 1 mois.
    • #24311 Répondre
      Kevin249
        I installed a new Navien tankless water heater over a year ago, replacing an old tanked water heater. I did not upgrade the propane line at the time, but I did of course change out the fitting inside the heater to work with propane instead of NG and adjusted the DIP switches correctly, and the Navien heater worked fine for a year. However, recently I’ve had a sporadic issue where the heater stops outputting hot water: the burner will come on only briefly, warming the water a few degrees above ambient, before it cycles off. This repeats every 10 seconds or so. The heater doesn’t display an error.
        After much troubleshooting (all air and water filters are clean, no exhaust issues, flow rate sensor is clean, etc), I’ve come to the conclusion that it might be either the undersized propane line, the regulator, and/or the outdoor temperature. The old propane line has a section of 3/8″ or 1/4″ rubber tubing, which is pretty small. The regulator on the (20 lb) propane tank is old and not adjustable; when the heater is doing its problematic-cycling thing, the regulator will briefly vent, and immediately the heater’s burner will go off. The heater continues to run for a few seconds, then makes a click/knock sound, stops running, then the burner cycles back on, repeat.
        This behavior seems correlated with cold weather, though it doesn’t even freeze in my area, and the problem isn’t consistent. Sometimes it’s fine for days, only to suddenly act up again. Nothing specific I do seems to fix it, but often after fiddling (unplugging heater, changing propane tank, etc), it randomly works again, but again, no specific action seems to solve the issue.
        Should I change out the regulator and increase the pipe size? If so, any insight into why it worked flawlessly for a year? Any advice or info would be much appreciated!
        192.168.8.1 192.168.100.1 192.168.0.1
      • #54912 Répondre
        cyrildelyon
          Traduit par google:
          J’ai installé un nouveau chauffe-eau sans réservoir Navien il y a plus d’un an, en remplacement d’un vieux chauffe-eau à réservoir. Je n’ai pas mis à niveau la ligne de propane à l’époque, mais j’ai bien sûr changé le raccord à l’intérieur du radiateur pour qu’il fonctionne avec du propane au lieu du NG et ajusté correctement les interrupteurs DIP, et le radiateur Navien a bien fonctionné pendant un an. Cependant, récemment, j’ai eu un problème sporadique où le radiateur arrête de produire de l’eau chaude: le brûleur ne s’allume que brièvement, réchauffant l’eau de quelques degrés au-dessus de la température ambiante, avant de s’éteindre. Cela se répète toutes les 10 secondes environ. Le radiateur n’affiche pas d’erreur.
          Après beaucoup de dépannage (tous les filtres à air et à eau sont propres, aucun problème d’échappement, le capteur de débit est propre, etc.), je suis arrivé à la conclusion qu’il pourrait s’agir de la conduite de propane sous-dimensionnée, du régulateur et / ou de l’extérieur. Température. L’ancienne conduite de propane a une section de tube en caoutchouc de 3/8 « ou 1/4 », ce qui est assez petit. Le régulateur du réservoir de propane (20 lb) est ancien et non réglable; lorsque le radiateur fait son cycle problématique, le régulateur se purge brièvement et immédiatement le brûleur du radiateur s’éteint. Le radiateur continue de fonctionner pendant quelques secondes, puis émet un déclic / cognement, s’arrête de fonctionner, puis le brûleur se rallume, répétez.
          Ce comportement semble corrélé au temps froid, même s’il ne gèle même pas dans ma région et le problème n’est pas cohérent. Parfois, c’est bien pendant des jours, pour recommencer soudainement. Rien de spécifique que je fais ne semble le réparer, mais souvent après avoir joué un rôle (débranchement du chauffage, changement de réservoir de propane, etc.), cela fonctionne à nouveau au hasard, mais encore une fois, aucune action spécifique ne semble résoudre le problème.
          Dois-je changer le régulateur et augmenter la taille du tuyau? Si tel est le cas, une idée de la raison pour laquelle cela a fonctionné parfaitement pendant un an? Tout conseil ou info serait très apprécié!
        • #54913 Répondre
            Il est possible que la panne provienne du détendeur gaz.
            Pourquoi ne pas vérifier ce point?
            quelle est la longueur de la conduite entre la citerne et le point de consommation?
            Quel est le type de tuyau utilisé?
            A quelle pression fonctionne l’installation?
        Répondre à : Propane tankless water heater issues (gas line sizing, regulator, temp
