Can you share some experience of boiler cooling tower water treatment?
Communauté Pratique Espace Professionnel Can you share some experience of boiler cooling tower water treatment?
    • #24415 Répondre
      Jesse
        Friend,
        I am Jesse. if you often need to have industrial boiler in your factory, then in order to save cost and protect environment, there are much cooling water to be treated, right?
        Today, I want to see if you can share some cooling water treatment process, either UV, CLO2, CL2, etc, surely, ozone application in cooling water treatment is best, like CO3 (ppm) in water, contact time, aeration mode, ratio of reuse water, come with PLC or without, water flow, total invest, and how much cost you save, etc
        If you also have question in your cooling water treatment, please list here so that we can help each other?
        Thks in advance
      • #55336 Répondre
          Hi Jesse.
          Thank you for your proposal, but we here only treat water intended for homes, for daily use.
          We have not, recourse to industrial processing.
          Thank you for your suggestion.
        • #55337 Répondre
          Jesse
            Dear Dani,
            Thks for your reply.
            There could be 2 questions in your forum, one no feedback to subscribed topic, the other no access for some time yesterday.
          • #55338 Répondre
              Our server experienced a failure which made the site unavailable several times over the past two days.
              I think you did not receive the feedbak because the server failure.
              Everything is back to normal now.
          Répondre à : Can you share some experience of boiler cooling tower water treatment?
